SIgnals and Straight DC
David,
The answer to your question is: "It depends on what it is."
My thoughts are that all avionics (anything with a signal or data on it) should be grounded to a common ground block.
Non avionics items like lights, pitot heater (items with a straight dc power line), etc can simply use an airframe ground.
Strobe systems, and the wires for those are typically a shielded bundle and that can be terminated to local airframe ground at one or both ends.
There can be exceptions to this, and that is where the manufacturers recommendation or empirical evidence comes in.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
