Old 12-17-2011, 12:00 PM
Bevan Bevan is offline
Default carb/ F.I. conversion question
I've changed out the carb on 0-360 (180hp) for vertical updraft fuel injection. I'm about to fab the airbox/filter components and have received Van's airbox kit made for carbs.
Can anyone give me the vertical dimension of their carb (I don't have it anymore) from the top mounting flange to the bottom flange? I want to know if I have to allow for a difference in height when following the plans for the Van's ram air filter box. I seem to recall a spacer has been required for others.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 12-17-2011, 02:37 PM
Don at Airflow Don at Airflow is offline
Default Lengths
MA4-5 6.375"
RSA-5 5.5"
Don
Old 12-17-2011, 07:06 PM
Thanks Don.
PM sent for parts request.
Bevan
Dual P-mags
Grand Rapids EFIS
Old 12-18-2011, 09:52 AM
chaskuss chaskuss is offline
Originally Posted by Don at Airflow View Post
MA4-5 6.375"
RSA-5 5.5"
Don
Don,
Would you mind adding the lengths of your various Airflow Performance Servos to this thread? What is the length of an MA4 [320] carb?
Charlie
