There have been numerous threads about the door latch pins not fully engaging the door frame structure, and I want to share a mod I have used in my plane to gain a bit more throw of the latch pins.
Here is a quick way to gain about .285" of travel on the lock pins.
Instead of using the pre drilled hole for a roll pin, or rivet to act as a travel stop, just drill and tap for a #6 screw.
Insert screw, washer and locktite it in place.
Done.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
