Old 12-16-2011, 11:48 AM
rocketbob's Avatar
Default how hot are the newer pitots?
I'm making my own heated pitot for the rocket which I finished machining last night. Only thing I have left is to make a heating element. I have a AN5814 pitot on my -6 that I'm going to check the temperature of, but as I recall they heat to a level thats way overkill and the newer heated pitots such as the Dynon don't get that hot. Can anyone tell me how hot is hot for one of the newer pitots, like when turning the unit on at ambient what the temp rise is?
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-16-2011, 02:56 PM
cbo111's Avatar
cbo111 cbo111 is offline
Red face
Wow, I thought your thread said "How hot are the new Pilots
Chuck O
TSP
RV-7A (sold)
Old 12-16-2011, 03:04 PM
Jamie's Avatar
Jamie Jamie is offline
Have you seen this reference from 'Lectric Bob?
http://www.aeroelectric.com/articles...erformance.pdf
It appears to contain the information you're looking for.
Old 12-16-2011, 03:08 PM
Jamie's Avatar
And how about the an5812 specification?
Old 12-16-2011, 03:12 PM
rocketbob's Avatar
Yes I have but judging by the current draw from looking at the Dynon (10A) its heating up the pitot significantly less than a 5814.
N8155F C150 flying
Old 12-18-2011, 08:20 AM
Echo Tango Echo Tango is offline
Thumbs up
lol, me too
Old 12-18-2011, 09:56 AM
CPSONE's Avatar
CPSONE CPSONE is offline
Default melting pitot cover
Hot enough to melt a vinyl pitot tube cover. Don't ask me how I know...
Mike
RV-6 emp, done-sold,
RV7A QB. Passed pre-cover and sold!
Disclaimer: Everything I say can be presumed to be wrong. Don't try this at home.
Old 12-19-2011, 07:24 AM
rocketbob's Avatar
Over the weekend I had a non-pilot friend over at the hangar and showed him the heated pitot I made. As soon as I said the word "pitot" he started cracking up thinking I said something else....
Anyway...
I don't think these things need to be hot enough to melt plastic to get the job done so I'm aiming for 250 deg F.
N8155F C150 flying
Old 12-21-2011, 10:43 AM
CPSONE's Avatar
Default Pitot cover melting
The pitot cover actually started to melt with the pitot heat having been turned off quite a while before. Just putting the airplane to bed and had been on in flight, parked the airplane and didn't wait long enough for it to cool down before putting the cover on and it started to melt! ooops.
Mike
Old 12-21-2011, 11:26 AM
longranger's Avatar
Default Thinking Out Loud...
No experience with heated pitot tubes, just an instrumentation engineer thinking out loud:
Do the newer units like the Dynon use temperature feedback (from an embedded sensor) to regulate the tempurature, or do all of them just run "wide open" all the time? With feedback control I wouldn't think you'd have to run it more than 40 - 50F, anything above freezing with a little margin to handle rapidly decreasing OAT. You might also want some kind of bypass in the event of failure of the feedback circuitry, maybe an OFF/AUTO/ON switch. Display the feedback temp on an EIS, maybe?
RV-7 TU 904KM (reserved)
Construction Log
