Go Back   VAF Forums > Model Specific > RV-1
Old 12-15-2011, 01:00 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default The RV-1 needs Wheel, Axles, Brakes, and Tires!
OK folks, we have had incredibly good fortune so far in the RV-1 restoration project. Almost all of the major RV vendors have contributed products and services to help us get the airplane flying safely, and a tremendous amount of volunteer labor has already been contributed. We now have an interesting opportunity for anyone that might be harboring a set of 600x6 wheels, axles, brakes and tires.
Van himself has molded a new set of wheel pants for the airplane. While looking at pictures of the existing airplane to sketch up a mounting system, he realized that it has been converted from the original 600x6 gear to 500x5?s. This is unfortunately going to look very odd, and quite ?un-original? ? especially with the airplane going into the EAA Museum next July. We really need to get the airplane back to stock, but would really rather not put a brand new (expensive) set of gear on an airplane that is expected to fly a hundred hours or so. We are hoping that someone might have a set sitting in a back corner of a hangar, on a non-flying airframe, or simply hiding in the attic.
What we need is 600x6 axles, wheels, brakes, and tires(with tubes). We can certainly find some new 600x6 tires, so we really need the hardware, and used would be great! If no one in the community has a set, we?ll have to see if we can find a vendor who could supply them, but let?s try this first. Please post here, and PM me if you have something ? this would be a GREAT way to get your name in the RV-1 log book!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-15-2011, 01:25 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I have a set of Matco master cylinders if you need them.
Dont know the part #, but came stock on the 10.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-15-2011, 01:49 PM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default 600x6
Paul,
I have a set of Mc Cauley wheels and breaks that came off my Cessna 180 last week. 1244 TTSN. Be glad to donate / trade them to the RV1. No tires or tubes.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 12-15-2011, 02:35 PM
JonJay's Avatar
JonJay JonJay is offline
I have a set of replacement brake pads with rivets. Small item but if they will work on whatever brakes you scrounge and they need some new pads, they are yours.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 12-15-2011, 03:05 PM
Special Delivery's Avatar
Special Delivery Special Delivery is offline
Just talked to Tom at VANS Aircraft Tires (Desser) and he's working on getting us tires and tubes! Gotta love our vendors for supporting this historic project.
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
Last edited by Special Delivery : 12-16-2011 at 08:13 AM. Reason: Corrected Dresser to Desser
Old 12-15-2011, 03:22 PM
rampilot rampilot is offline
Originally Posted by Special Delivery View Post
Just talked to Tom at Van's Aircraft Tires (Dresser) and he's working on getting us tires and tubes! Gotta love our vendors for supporting this historic project.
If this doesn't work out, I think I have a serviceable set of tires in the hangar. I'll double check tonight.
ram
RV-12 #459
230hrs
Old 12-15-2011, 06:27 PM
Default Grove Aircraft to the rescue!
Grove Aircraft has volunteered to furnish new axles and related hardware! The generosity of our vendors and manufactures continues to amaze me! The RV community is very special indeed.
www.RV-1.org
Old 12-15-2011, 07:04 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
I have a set of Cleveland brakes (used, needs rebuilding) and discs (new) that I acquired for the Breezy but no longer need. They're in the shop at the moment and I can get the part numbers if you need them, but they're for 6.00X6 1.5 inch axle wheels. The price is surprisingly reasonable.
Jeff Point
RV-6, RLU-1 built & flying
ATP, CFI, Tech Counselor, Flight Advisor & President- EAA Chapter 18
Milwaukee
Old 12-16-2011, 08:11 AM
Monkey Monkey is offline
Default Wheels
I have a pair of used Cleaveland 6.00x6 wheels that I took off a C-180 for a conversion to put on bigger brakes. I will dig them out and check the condition but, I remember they looked really good.
Randy Richmond
A&P, IA, Private Pilot
RV Builder
Owner:Richmond Aircraft Service
11563 Airway Blvd.
Roanoke, TX 76262
(52F)
817-401-809six
Inspections, Prebuys, Builder assistance,
Damage Repairs, Ferry Services
Old 12-16-2011, 11:10 AM
Ironflight's Avatar
Take a look at them Randy, talk to Jay, and see how they compare to the ones Jay has - I'll let you two decide which ones will work best.
I think that with Grove supplying axles, Desser the rubber parts, and either Jay or Randy's wheels and brakes - we have a set.
Excellent work people, simply excellent....less than 24 hours!
Paul
Paul F. Dye
