Old 12-14-2011, 03:00 PM
Leonard_Smith_nz Leonard_Smith_nz is offline
Default TMX O-360 + Micromonitor: Oil Temp Sensor
All,
I have this particular combination in my aircraft. After 5 years of faultless use the oil temperature sensor is playing up.
I'm almost 100% certain that I bought the sensor from Ron at Rocky Mountain Instruments, but I've not been able to get hold of him. I would appreciate if someone could assist with the identification of this particular part and possibly provide suggestions as to where it can be procured.
Image attached for clarification
Regards,
Leonard
[IMG][/IMG]
Leonard Smith
ZK-VRV (RV6: TMX O-360, Sensenich FP 85", VFR)
New Zealand
Old 12-14-2011, 05:59 PM
Eric Petersen Eric Petersen is offline
Default MicroMonitor Oil Temp Sensor
It has been a long time since I did this, but I think it is a sensor that the builder assembles using the part listed below.
Excerpt from Rocky Mountain Web site:
"Outside Air Temp or Oil Temp Sensor
This is an integrated circuit sensor AD590-JH. Digikey.com part number AD590JH. No other sensor compatible."
My assembly manual is at the hangar 35 miles away. I will look for it on my next visit. Hope this helps some...
Eric
Old 12-14-2011, 06:16 PM
Default Oil Temp Sensor Assembly Instructions
I found the Sensor assembly instructions on page 10 of the MicroMonitor Installation Manual on the Rocky Mountain web site (rkymtn.com). Good luck!
Eric
