Old 12-13-2011, 06:28 PM
DakotaHawk's Avatar
Default Am I overcharging my battery?
The no-load voltage on my PC680 has been trending down over the past year, and it's becoming noticeable when I attempt to start my engine on a cold day. The cold cranking amps just aren't what they used to be. Another thread about voltage drop across diodes got me thinking about how my system is set up.
My electrical system is based on Nuckoll's electrical schematic for a single engine/single alternator/single battery system. In a nutshell, during normal ops, power goes from
the Battery
to the Battery Contactor
to the Main Bus
to a Diode
to the Essential Bus
During abnormal ops, power goes from
the Battery
through a "Essential Bus" Switch
So here's the problem... Currently, I have my Alt Field Ckt Bkr and my Alternator Voltage Sense both come from my Essential Bus. But my Essential Bus voltage runs about 1.4volts lower than my Main Bus and my Battery voltage (due to the diode). So when the voltage regulator senses voltage, it's seeing a voltage that is 1.4 volts too low, and begins overcharging my battery in an attempt to get my Essential Bus up to 14.4 volts.
So now I'm wondering. Am I frying my battery? Should I swap the Alt Field and the Alternator Voltage Sense over to the Main Bus?
Scott "Grumpy" Stewart
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
Old 12-13-2011, 06:43 PM
kevinh's Avatar
kevinh kevinh is offline
I think you are. You want the voltage sense for the regulator to see the main bus voltage (not after the the >0.6V drop of the diode between the main and essential).
Moving the alternator field current over to the main bus is also a good thing, because when on the ebus you don't want to be wasting current to power the alternator that is presumably doing you no good. (If the alternator was working you presumably wouldn't be running from the ebus)
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 12-13-2011, 07:19 PM
Sparky's Avatar
Sparky Sparky is offline
I agree with kevinh. Why have your Alt Field and Alt Sense wired to the essential bus when the whole reason for the essential bus is in case of alternator failure? You could be overcharging the battery because of the voltage drop across the essential bus diode, as well as "wasting" current from the essential bus (powering the alternator field) if the alternator fails.
So my answer is: "Yes, you should."
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 12-13-2011, 08:18 PM
erich weaver's Avatar
I noticed you say you have a 1.4V drop. Are you sure? Should only be about 0.7, as previously noted. Check your numbers and if it's 1.4, you have a poor connection somewhere.
Erich
Old 12-13-2011, 08:19 PM
kevinh's Avatar
Actually depending on the diode used and the current draw, the drop can be higher than the standard 0.6V.
Old 12-13-2011, 08:26 PM
Sparky's Avatar
1.4 vdc drop is not unusual with a silicon diode in a fairly high current situation such as this application. A much lower drop (around 0.3 vdc) can be obtained with a Schottky diode set up. Search the archives for details.
Paul Winkels
Old 12-13-2011, 08:37 PM
Walt's Avatar
Walt Walt is offline
Bottom line is as long as you have the correct voltage at the battery (14.4 is ideal) then you're fine, if you have 15.5 at the battery thats bad.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-13-2011, 08:54 PM
Ok, I get it, but not sure why you think the original poster was referring to a high current situation. I certainly haven't seen that big of a voltage drop between my main buss and e buss.
Best to check what's happening at the battery, as suggested below.
Erich
Old 12-13-2011, 10:06 PM
DakotaHawk's Avatar
Erich
I incorrectly assumed that my bridge rectifier meant that the current flowed across two diodes - hence 2 X 0.7 = 1.4V. Turns out that the current only flows across one diode so the theoretic voltage drop is only 0.7V.
Arlington, WA
Old 12-14-2011, 07:12 AM
Wayne Gillispie Wayne Gillispie is offline
Scott,
Max charge voltage for Odyssey batteries is 15.0 V. If your alt is supplying 15.1 V to your main bus that could be part of the problem. While building I was using an AGM charger purchased at local auto parts store. I was charging my aux bat pc680 at 14.7-16.1 V. When I checked OCV 12 hours later it was always showing 75% SOC.
I purchased a 12A Odyssey charger online for $30 more than the wrong charger. After 5-6 rechargings the SOC was back up to 100%.
The other thing can be cold weather related. Capacity drops with temperature. A good charger, charge port and some preheating will help.
Good judgment comes from experience, and a lot of that comes from bad judgment.
