Old 12-12-2011, 10:37 PM
aarvig's Avatar
aarvig aarvig is offline
Default How do you drill out a pop rivet?
I just discovered that Vans must have sourced its CS4-4 rivets from 2 different sources. One does not sit as flush as the other. I have 3 pop rivets on my emp fairings that sit proud because of this. (Yes I countersunk with a 120 degree bit and dimpled with the 120 degree dimple die). I would like to drill these out but how the heck do you drill a pop rivet?
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 12-12-2011, 11:40 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Here is how I have done it.
Step one, use a small diameter pin punch to knock out the center mandril.
Step two, drill as normal, and if the rivet starts to spin on you, use a flat blade screwdriver or other tool to hold the head from spinning.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-13-2011, 12:31 AM
Bevan Bevan is offline
High speed, very low pressure so that the rivet doesn't start to spin.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 12-13-2011, 07:42 AM
2johns 2johns is offline
another way. Use flush sidecutting pliers and snip them off from the back side - the heads will then fall out.
Old 12-13-2011, 07:59 AM
sjhurlbut sjhurlbut is offline
Default method
I just drill it out like a normal rivet. If it starts to spin hold it with a pair of pliers on the back. Once the head is drilled off pull the back off with the same pliers.
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 12-13-2011, 08:10 AM
Paul LeDoux's Avatar
Paul LeDoux Paul LeDoux is offline
Check Avery Tools for a device to use when you cannot get to the rear of the rivit. Pricey but well worth it when you really need it.
Old 12-13-2011, 08:22 AM
N941WR's Avatar
N941WR N941WR is offline
Seek and Ye shall find.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
