The intakes don't have nuts, they have bolts. The exhaust has nuts (on studs).
Remove bolts, scrape old gasket junk off, ensure tube retainers are not bowed, Install new gaskets, ensure tube is centered in retainer, tighten to spec.
Next step - buy the SDS intake kit so it's on hand when you need to replace the next cracked intake gasket (and it WILL happen).
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
