Old 05-25-2006, 07:09 AM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Default Lycoming Woes Continue: 2005 C172S Snaps crank, throws prop
Check this out......Lyc is having problems.
http://www.aero-news.net/index.cfm?C...-f8a092cb4b01&
RV-7 Flying since 2004
1,100 hrs+
Old 05-25-2006, 07:30 AM
Jamie's Avatar
Jamie Jamie is offline
Wow...that gives me the creeps.
Kudos to the pilot for getting her on the ground in what I am sure was an underwear-filling experience.
Old 05-25-2006, 08:09 AM
cobra cobra is offline
How deep is the oil supply port for a C/S prop drilled?
From the looks of the separated prop/crankshaft, it appears that it might have been a factor.
Mike Parker
RV-9a under construction
w/Mazda rotary- Renesis
Old 05-25-2006, 08:30 AM
praterdj praterdj is offline
Default Lucky
These guys were very lucky the engine didn't run away and possibly cause a fire or something.
Great piloting. I'm sure it would have been very easy to panic or get distracted.
Donald Prater
Formerly 52F now Arkansas...Go Hogs!
RV-8 Empennage Underway
N-284DP (Reserved)
Old 05-25-2006, 08:32 AM
Jamie's Avatar
This was a 172. Fixed pitch prop w/ solid crank (I believe...unless something has changed recently).
