Old 12-12-2011, 09:12 AM
ctbecker ctbecker is offline
Default Wiring Needs - Vans Landing Lights
I'm considering the Van's wingtip landing lights for the 8A. The web store indicates that there are 2 lights in each wing at 75 Watts per. That's 300 Watts. Any thoughts on the wire size needed?
Charlie Becker
N464CB. RV8A(es)
Certificate Issued
Old 12-12-2011, 10:38 AM
longranger's Avatar
150 watts/wing divided by 12 volts = 12.5 amps. Conservatively, I'd use Table 11-3 in AC43.13 and go with 16awg and separate 15A CB's for each wing.
If you want to control each side separately (one side landing, one side taxi?), you'll obvioulsy need two switches. If you always want both sides to come on together you'll need a double pole switch.
RV-7 TU 904KM (reserved)
Construction Log
Old 12-12-2011, 11:31 AM
RFazio RFazio is offline
Default 2 Switches, Landing & Taxi
I put two switches in, one for landing and one for taxi. Landing puts on one in each tip aimed straight ahead. Taxi puts on the other one in each tip pointing down more, I have a tail dragger. I will admit they sort of just all light up ahead anyway. But they do really light it up when landing with all four on. The way I wired it, I still have a 15 amp circuit for each switch and #14s out to the tips. It's kind of a long run for 12 volt so I used the #14 wire size.
Richard Fazio
LI, NY
N966RV
RV-6 Slider
O-360
FP Wood Prop
Old 12-12-2011, 02:19 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default What he said
I go along with Richard. Because of the wire length I used 14 gauge. The 15 amp breaker should handle two lights.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 12-12-2011, 02:31 PM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
Default 3x
Same as Don & Richard but I used the 10A circuit breaker switches in Van's electrical kit, one for landing, one for taxi. Have not had either trip despite being on for as long as 45 minutes. If either trips, it will get replace with 15A.
Dave
M20C
