Go Back   VAF Forums > Education > Flight Testing
  #151
Old 01-01-2012, 08:14 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by gasman View Post
On the installed valve, back off the handle screw and un seat the handle and remove it. Take a 3/4" wrench and remove the cap. Pull out the shaft and selector cone. Drive out the pin and turn the shaft 180 deg and install the pin.
I was bouncing around the shop yesterday (low clouds and vis prevented flying) and took my spare valve apart. The above advice is 100% correct! I reversed the orientation of the "flat" relative to the nylon "ball" in five minutes. A very simple way to make the "machined D" handle work if you want to use it.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
