Old 12-11-2011, 12:28 AM
Flying Scotsman Flying Scotsman is offline
Default Gotta crawl back in the tail...
Anybody have a suggestion for a good, cheap "stand" for supporting the tail (-A model) while I crawl back in there to run some wires/static lines/etc.? I'm thinking of something like a jack stand with a threaded rod to go into the tiedown? Wonder if HF or HD or someplace might have something tall enough I could use or modify...
I have nightmares of being in the tail section and the plane tipping up and having the tail crash down!
Yeah, yeah...I know...not a problem for a tail-dragger LOL! But then all the blood rushes to your head!
TIA!
Steve-a-reno
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 12-11-2011, 01:09 AM
CPSONE's Avatar
CPSONE CPSONE is offline
Default tail support
This is what I use. but I make darn sure the main tires are well chocked.
("Don't try this at home" disclaimer...I am a trained professional...)
It's a 4x4 post that the tie down ring rests on and a fuselage cradle.
Put a large platform on the bottom of the 4x4 post t make sure it stays put.
Mike
RV-6 emp, done-sold,
RV7A QB. Passed pre-cover and sold!
Disclaimer: Everything I say can be presumed to be wrong. Don't try this at home.
Old 12-11-2011, 01:22 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Would it not be easier to "support the nose" and put the tail on / close to the ground?
Old 12-11-2011, 01:31 AM
Not with the engine on, I don't think...that worked just fine when there was no 300+ pounds up front (and the whole thing was basically in TW configuration ), but that sounds hazardous at this point...
Santa Clarita, CA
#8,000
Old 12-11-2011, 01:53 AM
Andy Hill's Avatar
I'd still offer it as a suggestion since:
  1. It is easier to support, and secure, a "nosewheel" than the tail area...
  2. If you have it "stablised" without you in the tail, it sets more stable as you get in there.
  3. If the worst happens, and the support fails, if the tail support fails, you and the aircraft are at risk. If the nose support fails, I doubt either you or the aircraft would be harmed.
  4. As you rotate the aircraft back, it gets more and more balanced - most NW types can have the nose lifted by moderate pressure on the HS.
Old 12-11-2011, 01:54 AM
KRviator's Avatar
KRviator KRviator is offline
I just use a $10 sawhorse from Bunnings Hardware with a bit of foam rubber strapped around it. Put it under a bulkhead to avoid stressing the skin.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 12-11-2011, 07:20 AM
Greg Arehart's Avatar
Two sawhorses set parallel to the fuselage and a 2x12 under the tail at the rear two bulkheads with a big piece of foam on it to spread the weight. Add pieces of 2x12 or whatever to make it the proper height. If you're really picky, cut the foam in a wedge shape so it supports the bulkheads equally.
I did the same thing to support the firewall before it was on the legs.
greg
Greg Arehart
N 7965A
Old 12-11-2011, 07:21 AM
Pat Stewart Pat Stewart is offline
I do not have pictures but a simple carpet sling is what I have used for years.
Pat
Old 12-11-2011, 07:59 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Flying Scotsman View Post
Anybody have a suggestion for a good, cheap "stand" for supporting the tail (-A model) while I crawl back in there to run some wires/static lines/etc....
I have several of these folding type sawhorses. What I like about the design is you can incrementally adjust individual leg height for maximum utility and when you are done using the sawhorse, the heavy gauge steel unit folds up for compact storage.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 12-11-2011, 08:55 AM
fatherson fatherson is offline
Nice adjustable sawhorses, Rick. (new tools! shiny!)
Yours look like they may be these Crawford ones:
- http://www.amazon.com/gp/product/B0009WG5ZI
which are about $35 shipped from Amazon or about $30 at my local HomeDepot.
Stephen
