Old 12-10-2011, 08:04 PM
LAMPSguy's Avatar
LAMPSguy LAMPSguy is offline
Default Cooling frontal area
This is full of assumptions.
Regarding cooling drag, are we concerned with the 2D cross section area that is perpendicular to the windline?
If so, I was wondering if making the cooling inlets slope rearward as they get closer to the tires would provide any benefit? Picture a sloped conic cross-section, looking head on looks like a circle, if you are on your back looking at the nose, it looks like an ellipse.
Here is my thinking: High power = more heat than lower power.
High power at high airspeeds = more airflow= plenty of cooling.
High power in climb = increased alpha (AOA) = reduced frontal area if typical circular/rectangular openings...but if as stated above then the openings would provide an increased opening area.
Do I have anything here?
RV-? in planning stages.
RV-14 #140050 SOLD
Permanently willing to contribute fuel for RV rides
Helicopter ATP/CFI(I)
ASEL/AMEL Commercial/Inst/CFI(I)
Aerobatic Instruction available
Atlanta based.
Old 12-11-2011, 08:03 AM
David Z David Z is offline
Default Difference in AoA
What is the difference in AoA from high cruise to climb speed? I can't imagine it being more than a few degrees.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
