Old 05-24-2006, 10:02 PM
Ted Farmin Ted Farmin is offline
Default Dynon compass installation
Looking for input as to where you have installed the remote compass unit
for the Dynon, more specific, on the RV4.
Ted
Old 05-25-2006, 12:01 AM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
This is not specific to the 4, but it worked well on my 6 and should adapt pretty easily.
http://home.mindspring.com/~rv6/RV6site/Dynon.htm
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 05-25-2006, 08:50 PM
pmercier's Avatar
pmercier pmercier is offline
Default dynon compass mount
This is the bracket I fabricated and is mounted behind the rear seat bulkhead and the top skin.
Philip Mercier RV-4 FK RV-7A flying
Abbotsford BC
http://members.toast.net/pmercier/project2
Old 05-26-2006, 07:58 AM
13brv3's Avatar
13brv3 13brv3 is offline
I put mine several places on the RV-3 I used to own, but the one that worked best was under the empennage fairing, between the horz stabs. In that case, there were no lights, or trim servos back there to cause any problems.
The current RV-8 already has it's EDC mounted in the same place, though I do have some concern over the current that has to run to the tail position light. I haven't wired any of that up yet, so it's too soon to tell.
A couple notes about mounting it near the rear of the baggage compartment- If you have an aft mounted battery, the current through the battery cables will make your compass readings wacky. Also, if you stow anything ferrous in the baggage compartment, that may also mess up the readings. This just depends on how ferrous it is, and how close you put the EDC to the rear baggage wall.
Rusty
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased, , flown, sold
A&P - 2018
Old 05-27-2006, 02:51 AM
Steve Sampson Steve Sampson is offline
Default Dynon magnetometer
Here is one installation I saw. It appeared to be quite a practical location to me. I think I would want to modify it though so you could adjust the plane of the magnetometer more easily.
Steve
#4478
