Old 05-24-2006, 06:35 PM
plythall plythall is offline
Default Alternative Static Air Source
I read in an EAA article that for an IFR equipped aircraft there should be a valve installed on the panel that allows the static air system to utilize the cabins atmosphere as the static source in the event of a static system failure. Granted that the cabin is not a reliable source, it is better than no instruments.
My question is where do I locate one of these valves, I remember seeing it in a 69 C172 but I can't locate the valve on Aircraft spruce or anywhere for that matter.
Thanks in advance for your assistance.
Peter Lythall
RV - & Builder in Fort St John, BC, Canada
Old 05-24-2006, 06:45 PM
kevinh's Avatar
kevinh kevinh is offline
I'm going to install one of these on my panel before I fly IFR (mostly because I want an excuse to work on the plane ). I want to use one of the NPT style fittings that plug into the bottom of an air compressor - anyone know of a good source?
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 05-24-2006, 08:33 PM
vlittle's Avatar
vlittle vlittle is offline
Default Alt Static
I tee'd off my static line, dropped a length of tubing down about 12" to a bracket riveted to the fuselage longeron.
I then used an NPT nipple and a locking fuel drain. Since this is the low point of the static system it doubles as both a drain and an alternate static source.
I like the idea of a petcock instead of the fuel drain, because it might be a bit easier to open in flight.
Vern
Old 05-24-2006, 08:52 PM
AlexPeterson's Avatar
Default Simple alternate static system
I used silicone tubing to plumb my instruments behind the panel, so for an alternate source I simply put a straight connector in the line, flush with the bottom of the panel, and easily accessible in flight. For alternate static, I simply pull one of the tubes off from the barbed connector.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 05-25-2006, 12:27 AM
George in Langley BC George in Langley BC is offline
Default Alt Static
Hi Peter
I use a Curtis CCA 1550 quick drain valve. "T" into static line and mount on a bracket under the left arm rest 6A & 7A.
George
(worked as holiday relief controller in YXJ tower, summer 1965)
George McNutt / Langley BC / 6A Sold / 7A Flying.
Old 05-25-2006, 05:44 AM
sadams sadams is offline
I wanted a nice looking switch mounted in the panel, so I used a miniature 3 way routing valve that accepts fittings for the static lines. Hook up the input to your instruments, one output to the static port, and leave the other output open. It works great and looks nice. I got mine from a friend, but it is similar to the first one shown on this link.
http://www.specialtymfg.com/miniatur...s1/default.asp
Old 05-25-2006, 06:28 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Trash or Treasure?
.........My question is where do I locate one of these valves, I remember seeing it in a 69 C172 but I can't locate the valve..........
A few years ago, I picked up a used one for $20 out of a wrecked Cessna at the salvage/scrap yard in Staunton, Il. http://www.cent-air.com/ For a real eye opener, visit one of these places sometime! This particular one has a grass runway, but you must call first because there might be a few wrecks parked on it. In any event...give em a call.
I don't know if it is true or not but someone once told me a simple aquarium valve would work just as well.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 05-25-2006, 07:39 AM
RV7ator RV7ator is offline
I installed a branch T in the 1/4 hose between instruments. The branch is a 1/8 pipe thread with a cap on it barely visible below the panel. Just unscrew it. I'd be wary of installations pulling a line off a barb. It's either too easy with failure potential, or you're struggling to work it off in flight, needing both hands.
John Siebold
Boise
-7 (180 hrs), -7 finished airframe
