Old 06-23-2009, 02:20 PM
Geico266's Avatar
Geico266 Geico266 is offline
Talking pesky oil leak solved finally - quick drain
I was changing oil today and trying to narrow down where a small oil leak is coming from, hard to do on a Lycoming I know, but I really think it is the quick drain!? I can see where oil is "seeping" around the blue collar.
Anyone else had a problem with theirs?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 06-23-2009, 02:29 PM
victor's Avatar
victor victor is offline
Default quick drain leak--
The o-ring needs to be changed from time to time on the quick drain. The heat and pressure causes the o-ring to become hard and brittle. Not a big job to remove the drain and replace the o-ring.
Vance Noles (vaf#139)
RV-9A--370+hrs
RV7-A qb @ 100%-58hrs
TMX-IO360, Hart CS,
IFR, Tru-Trak ap,
Bradenton, Florida
Old 06-23-2009, 02:34 PM
Geico266's Avatar
Thanks for the heads up! The "annual" is coming up and that will be a good time to tackle that major job.
Old 06-23-2009, 02:56 PM
fl-mike's Avatar
fl-mike fl-mike is offline
My Saf-Air leaked a tiny bit when new. Called 'em and they INSISTED on sending me a new unit. I said "just send me some new o-rings". "Nope, we're gonna send you a new one just in case there's a scratch or something in the seal area." Okay. Didn't even ask for the old one back.
Mike W
Venice, FL
N164WM
Old 12-08-2011, 03:49 PM
turbo's Avatar
turbo turbo is offline
Talking pesky oil leak solved finally.
its has been quit a while with this leak and i never thought to suspect the quick drain. 50 cents worth of parts and i am very happy. those o-rings only had thousands of hours on them. what a great invention. i can dump my oil by going thru the oil door to hook up a hose. i seem to get a nice click when i close the valve now. keep on pounding or flying.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 12-08-2011, 08:27 PM
bhester's Avatar
bhester bhester is offline
Default o-rings
Anything special about those o-rings? Were did you get yours? I think mine needs to be changed also. Know the size?
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 12-09-2011, 03:19 AM
s24789 s24789 is offline
Turbo we did our first run last Saturday and noted oil on the cowling directly down from our newly install QD. Was the leak around the treads where it goes into the oil pan or from the inside of the QD?
Phelps
Old 12-09-2011, 10:51 AM
Noah's Avatar
Noah Noah is offline
I was watching my hangar mate do an oil change the other day and he has a piece of tubing connected to his quick drain valve routed up to his oil door where it is coiled up and tie wrapped to his engine mount. This way, if the valve leaks it will flow into the flexible tube but does not have enough pressure to climb all the way up to the oil door. To drain the oil, he reaches down, opens the valve, and starts a syphon to drain the oil. A little more weight to carry around but don't need to remove the lower cowl for an oil change and lower risk of an oil leak. Just a thought.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 12-09-2011, 11:09 AM
Sam Buchanan's Avatar
been here awhile
An oil change is an excellent time to pull the cowl for a good inspection of the engine compartment. Call it a forced inspection if you wish.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 12-09-2011, 12:13 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Agree with Sam. An oil change is a great opportunity to perform a conditional inspection. Why limit an inspection and your chances of discovering a problem only to once a year? Even with my three bladed prop, removing the lower cowl is not that big of an issue so why not do it and gain unrestricted access and an unrestricted view of the entire engine area?
P.S. Oh, and Turbo, I have to ask. What exactly is that advertisement underneath your quick drain? It makes for an interesting back drop.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
