I figured I'd post this here (versus the tool section) since a pneumatic rivet puller is seldom used on models other than the RV-12.
For those of you who use a pneumatic puller, have you found out how frustrating it is when the rivet 'stems' continually fall out of the slot in the gun's tailpiece? I had them falling out all the time and decided to find a solution. The cost? About $3.00. I went to ACE Hardware and bought a piece of flexible plumbing / sink drain tube, 1 1/2" inside diameter, 12" long. They sell it by the foot. I also bought a cork that fits in the end. Remove the tail piece from your gun that currently catches the rivet stems. In its place, slide the flex tub over the end of the gun and cap it off with a cork. The tube can be bent to be out of your way, and will catch 10-times more rivet stems than the original method, and they won't fall out if you tilt the gun the wrong way. At the end of the work session just remove the cork and dump the stems into the trash. Works great!
