Looking at the mag where the ignition harness would screw on, with the mag coil housing up, number one is at the 11:00 position. The mag rotation and thus the direction the wires will clock to the firing order is listed on the mag data plate.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
