Derrick, welcome aboard the good ship VAF!!
Good to have you here, this is THE place for info on things of an RVish nature.
The hardest part of the lighting project is going to be running the wires, far as I know. It will more than likely require a series of holes to be drilled in the ribs, for a conduit. It can be done with a unibit, and a bunch of extensions----just have to be patient.
For the actual lights, my suggestion is to use a Duckworks leading edge setup.
There is a lot of info already here about running conduit, time for you to get familiar with the search function.
Again, welcome aboard, enjoy the ride
