Originally Posted by HBpilot
sorry I should have been more specific. I am just starting the project and working on the vertical stabilizer.
Ah, thanks, that helps narrow things down.
In general, search the forum on the word "scratch" and the name of the part you are working on.
In specific,
this is the thread that comes to mind as regards good guidance for how to dress out scratches in highly-stressed components. See Dan Horton's diagrams, they're a good explanation of what you're looking for when dressing out scratches in critical parts.
For scratches in the middle of a skin, away from edges and rivet holes, unless they are very long or go through a substantial percentage of the skin thickness, the advice is usually "build on." But it is best to approach them on a case-by-case basis. You'll find it easier to get specific advice if you post a photo of the scratch in question.
Scratches to be especially careful of are those in the edges or corners of cyclically stressed components (shear webs, spar caps and flanges, etc), or passing through fastener holes of same.
