I installed mine last night.
Basically did the squaring bit mentioned above. Measured the distance from outboard edge of skin for top and bottom in two places, connected the dots. That gave me a line running parallel to the wing tip the correct distance from the wingtip. The I measured from the rear of the LE skin on each side of the already drawn line and connected those dots, leaving me with basically a +
The center is where the small hole goes. I measured one of the delrin pieces hole to hole for the screw distance, then divided by two. Measured that along the king perpindicular to the wingtip and made a mark. I used a small punch to make the mark. Drilled it in place, then clecoed the bottom Delrin fitting to that hole and positioned it so that the line I drew on the skin was visible through the other hole, then back-drilled it. Final hole size is 1/8" (#30). I dimpled by putting the female die in a bucking bar, and using the rod from my C-Frame for the male die. Takes two people, hit with a mallet.
For the drain hole on the bottom:
I removed the drain fitting on the air-water separator clecoed on the top, then turned out the lights. I turned on a flashlight and shot it through the #60 opening on the top of the wing. This projected a fairly large spot on the bottom of the wing. Using a Sharpie, I marked the center of that spot as best I could, then drilled there using a 90 degree attachment. Hole size is #40.
After drilled, deburring, dimpling, etc, I cleaned the skin interiors and delrin pieces as best I could, then put a VERY small bead of proseal on the outside edge of the delrin, then positioned it and pushed into place. The Proseal held it there while I inserted and tightened the screws and nuts.
I will let the proseal dry and finish mounting the LE on on the spar before connecting the hoses.
If I were to do i again, I would measure and drill before riveting the wing together. This will make the dimpling process MUCH simpler. (Except for the drain hole. I wouls still do that after positioning the delrin on the riveted LE.
Hopefully, this is helpful to someone.
Oh yeah. Measure twice, drill once. That prevents you from having to put three extra rivets in your skin.
