Thanks, I thought that might be the case but had not ever really looked into it.
In my Extra 230 I had an angle valve with 10:1, it was around 230hp. From level flight wide open I could do a 5-6g pull and get around 1500-1800' vertical. Don't remember the speed I would get WOT level, it was 15 years ago, but I'm guessing between 160-180mph. The wing leading edge and wing itself on a 230 is very thick compared to an RV, and does create more drag. I'm may be wrong but I seem to remember weight of the 230 was around 1050lbs, so a 230hp parallel valve engine in the RV should have a very nice effect on performance.
I guess it's a holdover from competition - you can never have too much roll rate or too much horsepower!
High compression it is!
