View Poll Results: Emergency Decent Poll
Spin 3 3.23%
Slip with flaps 24 25.81%
Slip without flaps 8 8.60%
Dive with flaps 6 6.45%
Dive without flaps 34 36.56%
Other 20 21.51%
Multiple Choice Poll. Voters: 93. You may not vote on this poll
Old 11-28-2011, 12:54 PM
grantcarruthers's Avatar
grantcarruthers grantcarruthers is offline
Default Emergency Descents
What's the fastest and safest way to lose altitude?
Spin might be my first choice, better be good though
Full flap slip? Hard to mess up, likely not be faster than a spin
Dive
If you had to get down quick, what would you do
RV-8, Both wings with top skins on
-4 bought flying
Old 11-28-2011, 12:55 PM
bkthomps bkthomps is offline
pull power, nose over......keep below VNE
Old 11-28-2011, 01:07 PM
Rhino889's Avatar
Rhino889 Rhino889 is offline
I was taught this but with the addition of a 45-50 degree bank. Lift vector is a factor.
VAF DUES 7/13, 12/13, 03/14
Founder/Director
www.Aircraftwraps.com
This is my personal account and does not reflect the official communications of Aircraftwraps.com. We have retained a username for such correspondence. I post about formation, eating, aerobatics and pilot stuff .
Old 11-28-2011, 01:11 PM
DCat22's Avatar
DCat22 DCat22 is offline
+1
Spiral at high bank is the in the POH of a number of certified planes too.
-Rick Greer, VAF #2492
Old 11-28-2011, 01:13 PM
sailvi767 sailvi767 is offline
It would depend on why you want to get down so fast. If you had a structural problem and wanted to stay slow then flaps extended and idle would be best. If you want the very fastest way down a 6 G spiral dive at VNE would do the trick. Something more like 2 or 3 G's in a spiral down would however be much more comfortable and still allow for a high rate of decent.
George
Old 11-28-2011, 01:25 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Would depend on the type of emergency situation...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-28-2011, 01:27 PM
RV6_flyer's Avatar
IF you were smart and built your RV with a Constant Speed prop, all you need to do is push the RPM forward to high RPM and pull the throttle to idle. Now push the nose down. This is a TEST FLIGHT and EMERGENCY maneuver only! (done three times on my RV-6) I do NOT RECOMMEND it as a NORMAL or Standard Operating Procedure.
On my RV=6, I have a 45 degree down line, 4,000 FPM rate of decent, engine gauges are all in the GREEN and airspeed us UNDER REDLINE. Yes it is in the yellow zone at 180 KIAS. (Redline = 183 Kts)
Need to come down faster, then throw in some steep bank S-Turns.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-28-2011, 01:29 PM
Flyfalcons's Avatar
Flyfalcons Flyfalcons is offline
I like how Gary subtley called all the fixed pitch RV'ers here dumb.
Ryan Winslow
Old 11-28-2011, 01:30 PM
Bavafa Bavafa is online now
Agreed and how much you need to decend to?
We all have learned [hopefully] slowing down to the stall speed can bring you down really fast.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-28-2011, 01:44 PM
DCat22's Avatar
What is your FPM if you do all that, plus a 3G or 6G spiral? Sounds like that would be about max...ie. my feet are burning.
