Old 11-27-2011, 07:07 AM
rvator51's Avatar
rvator51 rvator51 is offline
Default Lord Mounts J9613-40 versus J9613-49
Does anyone know if the -40 lord mounts are the same thickness as the -49. I need to replace mine and there are some good deals on ebay for new -49 lord mounts. Seems most people use the -40 but some are using the -49. I want to make sure they are the same thickness or I will have problems with gap at front of cowling.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 11-29-2011, 06:36 AM
mahlon_r mahlon_r is offline
The rubber biscuits are the same size and I believe the center spacer is the same length. But they are of different resiliency. As I recall, the -49?s were typically used on 320/360 engines in Cessna installations and the -40's were used on Piper aircraft with the same engine models.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 11-29-2011, 08:40 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
The Lord 9613-40 and -49 only differ by one of the sandwich elements. The spacer has an identical part number so the mounting dimension will be identical.
It seems the old Lord corp. documents were much more informative -
http://www.n2999c.com/N2999C-info/ai...mount_lord.pdf
The part number data is on page 34 for the three parts that make up the assembly.
It's a pity that this on-line copy does not clearly reproduce all of the Lord installation drawings...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-29-2011, 09:13 AM
chaskuss chaskuss is offline
Default Care of Lord Mounts
Gil,
Great document. Thanks! Here is a link for inspection and care of the engine mounts on your RV. See
http://www.lord.com/products-and-sol...ord-mounts.xml
Charlie
Old 11-29-2011, 09:50 AM
az_gila's Avatar
Unhappy
Originally Posted by chaskuss View Post
Gil,
Charlie
Yep... I found that, and also noticed it does not cover the 9613 parts...
Some interesting factoids in the old scanned document - the IO-320 and IO-360 (page 78) moves forward 0.036 inch under take-off thrust...
Gil Alexander
Old 11-29-2011, 10:06 AM
snipped
Gil,
I noticed that too. The closest listing is for 9612. The document's first sentence warns:
Where a component maintenance manual is available for a system, its requirements take precedence.
It does outline how these mounts tend to distend over time.
Charlie
Old 11-29-2011, 10:18 AM
rvator51's Avatar
Thanks everyone for their help! Looks like the -49 will work ok then for the RV as a replacement for the -40 at a lot cheaper cost.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
Old 11-29-2011, 10:54 AM
rhill rhill is offline
Which is best for vibration? has the least deflection under load? I see one has a steel spacer the other has a rubber football ...... Did I just answer my own question!
Old 11-29-2011, 12:12 PM
az_gila's Avatar
Exclamation
NO, both of the parts use the same spacer part number J-12334-1
See page 34 of the above link.
The only difference is one of the rubber blocks.
Reading the hard-to-read installation drawings at the link, it seems like the 9613-40 mount is softer than the 9613-49 since it has more downward deflection at 1 g with take-off torque.
Gil Alexander
Old 11-29-2011, 06:27 PM
Gill, OK thank you,If I may ask which one will you use in your 6 project?
