Old 11-26-2011, 01:16 PM
alcladrv alcladrv is offline
Default Is my ACS keyswitch bad?
I started up my -7A normally on a 40 degree F day, taxiied about 500 yards after a 1 minute warmup and then my O-360 just quit on its own.
When I tried to restart, I could rotate the keyswitch, but not push it it to start. Nothing. Then I removed the keyswitch from the panel and jiggled the connectors. I then tried and it restarted normally and both my left mageneto and right Lightspeed checked normal.
The plane has a little over 700 hrs. over 6 years with about 500 cycles (or starts). What is the lifespan of these switches? Is is just "cheap "insurance to replace it so I don't get stranded while on the road?
Mike
Old 11-26-2011, 03:06 PM
GLPalinkas's Avatar
Default Keyswitch
I read in another thread that there is a Service Bulletin on the ACS key switch and that there is a kit to rebuild it for your very reason. Can't find the thread though.
Check this link to ACS:
http://www.aircraftspruce.com/catalo...nswitchkit.php
Venice, Fl
Last edited by GLPalinkas : 11-26-2011 at 03:08 PM. Reason: service bulletin added
