Old 05-22-2006, 08:57 PM
briand's Avatar
briand briand is offline
Default Ouch, I see Spruce doubled the price of their Alodine 1201
Anyone know of a cheaper supply?
Old 05-22-2006, 09:19 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Around me a couple boating stores have it - although like everything else in boating, it is a rip off there too. You might try calling around - being in Grand Rapids, you might luck out.
Good Luck,
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 05-22-2006, 10:09 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Auto paint supplies
Try your local DuPont auto paint supplier.....
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-23-2006, 04:54 AM
PJSeipel PJSeipel is offline
I bought the powder from Eldorado Chemical. 1 lb of the stuff will make 10 gallons or so. 5lbs will probably do 2 airplanes. Not sure what the prices are now, but 5lbs was about $100 when I bought mine.
Dorado Kote 1
Old 05-23-2006, 06:03 AM
plaurence plaurence is offline
Dorado Kote 1
Allied Plating in Miami has it for $187 for ten pounds. One can mix it to one pound per thirteen gallons. About a buck fifty per gallon.
Peter
Peter Laurence
RV9A Fuse
Old 05-23-2006, 04:52 PM
mikehoover's Avatar
mikehoover mikehoover is offline
Default Finishmaster
If you have a Finishmaster locally, you can get DuPont 225S (surface prep) and DuPont 226S (equivalent to Alodine) without shipping costs. Find the nearest one at www.finishmaster.com. Hope this helps.
Mike
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 05-23-2006, 09:58 PM
briand's Avatar
I already called them. You can't mix the dupont with henkel 1201 (which is what I have left over from the Emp.) and the Dupont is a 1 to 1 mix so you only get 2 gals. as opposed to the henkel (which is a 2 to 1) where you end up with 3 gals.
Old 05-23-2006, 11:11 PM
az_gila's Avatar
Question Why mix?
Why mix?
Just use one up, and then switch.
The acid step and the alodine (conversion) steps are independent and do not need to be a "matched set" of chemicals. There is a wash step between the two...
gil in Tucson
Gil Alexander
Old 05-24-2006, 04:00 AM
briand's Avatar
Originally Posted by az_gila
Why mix?
gil in Tucson
I need enough to dip my parts, I don't like the brush method.
Old 05-24-2006, 07:48 AM
az_gila's Avatar
Smile Try it
Try a small test case with the DuPont 225S at 2 to 1. If the color changes, it's OK.
DuPont's data sheet talks about no dilution and "direct application" (brushing on) - they don't mention the immersion bath method.
http://www.performancecoatings.dupon...19291_226S.pdf
The Henkel (Alodine 1201) is also no dilution for brushing, and the 2 to 1 is for an immersion bath.
http://www.aerospace.henkel.com/Imag...lodine1201.pdf
Note that the bath must be at 70F or warmer to work correctly at this dilution.
If you are doing large sheets, I like the use of a water misting bottle (an all-plastic one from the drug store) and just spray it on undiluted. Small parts can then be done in something like a plastic shoe storage box, filled to an inch deep or so.
{An idea from the old Matronics list... ..}
good luck ......gil in Tucson
Gil Alexander
