Old 11-23-2011, 06:29 PM
Walt's Avatar
Walt Walt is offline
Default Exhaust System Inspection, Check this out!
This is what happens when you don't keep an eye on things. It started with a broken exhaust hanger who knows how long ago (which I neglected to get a pic of) and then progressed to a cracked flange. This one was likely only hours away from a compelete seperation
This aircraft has approximately 275 hrs on it!
The Tell tale signs...
A little closer view
Then around the backside....
The crack is approximately 75% of the circumference of the flange, most of it was around the back side not really visible unless you inspect with a mirror.
Moral of story, pull both cowls every oil change and use the opportunity to do a thorough visual inspection with flashlight and mirror. When checking the exhaust system be sure you give it a good tug to check the integrity of the supports.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-23-2011, 06:37 PM
db8's Avatar
db8 db8 is offline
Default Wow
Holly smokes.....Thanks for posting that Walt. Dave
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
Old 11-23-2011, 06:48 PM
JonJay's Avatar
JonJay JonJay is offline
Another good catch Walt. I would also have a bit of concern over the crack developing exactly along the weld line, not just in the vicinity but exactly following it.
Perhaps Larry or Russ could chime in on that observation.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-23-2011, 06:59 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Hey Walt, do the welds going down the pipe (from the flange) indicate that they've cracked before? I'm guessing so...and wondering why that is. Could it be an indication of an engine that vibrates too much?
Sonny W
Boise, Idaho
RV-7A Flying!
Old 11-23-2011, 07:06 PM
FORANE's Avatar
FORANE FORANE is offline
I had the same crack in the same location. We welded it once. It reoccurred but the second time I didn't notice it until I heard what sounded like a shotgun going off immediately followed by the sound of an engine with no muffler shortly followed by a significant drop in EGT on the effected pipe. The pipe completely separated at the flange.
I did not have a faulty hangar but it cracked just the same.
The last time I took it to a friend who does a little metalwork: Gene Fulton of Fulton racing engines.
http://www.fultoncompetition.com/Ful...tion/Home.html
Gene welded 2 support tabs between the flange and the side of the pipe. It has not cracked again.
Old 11-23-2011, 07:12 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Originally Posted by rvmike View Post
Had the same crack happen at 400 hrs and called vetterman. He said that if you don't keep the slip joints lubed (mouse milk ) it will crack because there is no more movement and the weld is the first to go. Gone another 400hrs and no problems
Mike,
You hit the nail on the head!!! and... mouse milk does the trick.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-23-2011, 07:56 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
If you're asking about the doubler plates with the holes in them, that's the way the Vetterman pipes come brand new.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
Old 11-23-2011, 08:03 PM
bret's Avatar
bret bret is offline
Look at the gap at 10 and 2 O'clock, Just guessing here but these areas would set up a stress point for vibration work hardening to begin, if the weld was even the vibration load would be spread evenly across the weld-flange...?
Old 11-23-2011, 08:11 PM
jrs14855 jrs14855 is offline
Default EXHAUST
What kind of exhause hangar?? Attaching the hangar to the airframe puts far more stress on the exhaust than attaching the hangar to the engine. In my opinion there should be symmetrical doublers on both sides of the pipe. This type of failure is common on many types of exhaust. Welding all around a pipe to flange sets up stresses that lead to failure.
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Originally Posted by LifeofReiley View Post
Mike,
It kind of bugs me when I am suddenly informed that I was supposed to be doing something all these years, when it was not in the documentation. I live in the middle of nowhere.
If you are supposed to put mouse milk on those joints I would expect that to be in the documentation, and it wasn't in mine. I haven't had any problems with my Vetterman exhausts for the past 1,000+ hours and 10+ years, but if I am really supposed to take this action I would like some official notification.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
