Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #11
Old 11-23-2011, 06:56 PM
UnPossible's Avatar
UnPossible UnPossible is offline
Nope - no amp draw... In the morning I'll connect the lap-top and try and redo that pin assignemnt and see what happens.
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 11-23-2011, 08:00 PM
SmilingJack's Avatar
Default Sounds good
Make sure you don't physically remove pins, just delete them in the program and put them back exactly like you had them.
Hey, like I said, I'm not a pro at this, just a thing that happened to me twice, once doing pmag work and once playing with something else I did.
Good luck Jason.
John Mastro
RV-8
Old 11-27-2011, 07:08 PM
UnPossible's Avatar
Ok - I may offically be an idiot.... I think it was working the whole time.
The LED on the P-Mag is recessed in the case, and somewhat difficult to see. In my well lit workshop, I have to lean waaaaay over the engine to see if the LED is lit. It very likely was lighting up the whole time.
I did deactivate the output via the VP-X software and reactivate it, but not really sure that it did anything.
Just running power to the P-Mag still does not show an amp draw(with the red light, with the LED on. I'm going to call the guys at E-Mag to make sure that this is correct. Again when testing the P-Mag plug with a mult-meter, everything switches correctly.
Jason
Jason Tremble
Paid for 2020
Old 11-27-2011, 07:37 PM
N941WR's Avatar
N941WR N941WR is offline
Two words, "Dental Mirror".
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
