Old 11-22-2011, 01:06 PM
704CH's Avatar
704CH 704CH is offline
Default DPDT on on on - question
Hey guys, quick question about the operation of this switch when wired per AeroElectric Connection..
If wiring such that it operates per:
  • Down=Off,
  • Middle=left landing light,
  • Top= both landing lights..
Does the circuit for the left landing light break the instant you flip to the top position? Then come back on with the right light?
or does the circuit remain constant for the left light when the right is added to the circuit?
Chad
Sammamish, WA
RV-7 Standard Build - Tip UP
Flying ! As of 032913
Superior IO-375, WW200RV, Single Lightspeed, SkyView, GTN
http://www.704ch.com/
Old 11-22-2011, 02:16 PM
Sparky's Avatar
Sparky Sparky is offline
In your example, the left circuit should not break if the switch is working correctly.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 11-22-2011, 07:30 PM
704CH's Avatar
Thanks, I am planning my switches now and don't have one to test, Or I would have been able to figure this out myself. With this info I am planning on a DPDT (on on on) switch wired this way for the following:
Left/Right Landing lights
Nav/Strobe Lights
Master Bat/Alt Field
Chad
Sammamish, WA
Old 11-22-2011, 07:36 PM
Mel's Avatar
Mel Mel is offline
Default Keep in mind that.....
Nav and strobe lights should be on separate switches. There are times that you want/need the nav lights but not strobes, such as in clouds or light fog where the strobes will flash back in your face; or on the ramp at night where the strobes will blind other pilots.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-23-2011, 04:36 AM
rleffler's Avatar
rleffler rleffler is online now
A slight difference in semantics.....
Nav and strobe lights should be independently switchable.
With the VP-X, I have them on the same switch to conserve panel space and switches. Up is just nav and down is nav and strobes.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-23-2011, 10:52 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Default An added thought
Nav/Strobe Lights
An added thought is to connect the power wire from the buss to terminal #1 and jumper to terminal #4, then connect "middle on" light to terminal #2 and "up on" light to terminal #5. This way there is never any power to terminals #3 and 6.
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 11-23-2011, 11:13 AM
scsmith scsmith is offline
Default another reason for separate switches
What Mel and Al said are true. So based just on that reasoning, you could use a single switch,wired off, nav, nav+strobe.
BUT
Sometimes, I turn the strobes on but not the nav lights. When? Daytime.
So you might want to find a four position switch. Off, nav, strobe, both. Other than rotary switches like a mag ignition switch, I don't know if they make a four-position switch.
So, 2 switches for me.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
