11-22-2011, 09:51 AM
Hartzell to WW200RV
I am new to the forum and was led here by a member because of my interest in purchasing a 7 or 8. What a great source of information and a fantastic group of enthusiasts! I was looking at an RV8A that is for sale. The A&P owner (not builder) changed the prop from a Hartzell to a WW200RV. In doing this he asked the local FSDO for an amendment to the operating limitations and permission to re-inter phase 1 testing to verify the operation of the prop. This was granted and completed. But the FSDO added a restriction to the operating limitations that prohibit the aircraft from any aerobatic flight - not just for the phase test but forever.
My questions - Was this request necessary to change out a prop on a previously tested and registered experimental aircraft? How big of a nightmare would it be to get such a limitation removed?
11-22-2011, 09:59 AM
Senior Curmudgeon
Welcome to VAF!!!!
Wolfgang, welcome to VAF.
Good to have you aboard.
The go to guy for many DAR issues is Mel, he can answer your questions for you.
Here is his contact info, send him a PM.
http://www.vansairforce.com/community/member.php?u=1224
Just realized you are in Florida, you have another DAR in your area that you could talk to also, Vic Syracruse.
http://www.vansairforce.com/community/member.php?u=1415
Good luck, and again, welcome to VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-23-2011, 08:00 AM
Thanks for the information Mike. I contacted Vic and promptly got an answer. "Yes, it is required to contact the FSDO for a major change such as a propeller. The limitations for aerobatic flight should never have been added, but they should be easy to rectify with the same FSDO. They may require you to demonstrate the aerobatics with the new prop." I say again, great forum!
Wolfgang
11-25-2011, 09:46 AM
Wolfgang
Demonstrate aerobatic flight!? Its a RV... I thought was done on EVERY flight?
If you need someone, I'd be happy to "demonstrate" the heck out of it!
VAF DUES 7/13, 12/13, 03/14
Founder/Director
www.Aircraftwraps.com
This is my personal account and does not reflect the official communications of Aircraftwraps.com. We have retained a username for such correspondence. I post about formation, eating, aerobatics and pilot stuff  .
11-28-2011, 09:31 AM
No kidding! My thought exactly. Now you can imagine my surprise to come across an 8 that specifies "no aerobatic maneuvers". Like buying an enduro motorcycle that says "for street use only". But everyone to their own.
11-28-2011, 09:48 AM
Wolfgang,
You might consider contacting Whirlwind and getting a statement from them that there are no aerobatic limitations on their prop, and none on your prop/engine combo, or your prop/engine/airframe combo...if they will provide you with such a statement.
I have several buds that have WW props on RV-8s, and to my knowledge, none have aerobatic limitations imposed upon them. Of course, it will carry more weight with the FSDO coming from WW, versus from word of mouth.
Going in with some documentation should make it a slam dunk (hopefully  , I recently did a prop change and found the FSDO easy to work with...hopefully you will find the same)...and should get your enduro back out on the moto-trail!  Good luck!
Bob
11-28-2011, 12:59 PM
Now that's funny!
Founder/Director
11-29-2011, 08:01 AM
Huh?
Changed from a 3 blade MT to the 2 blade Hartzell BA prop before heading out to Reno this year. My local FSDO didn't care one way or another if I went back into Phase 1, as it was not a major change in their eyes (CS to CS), but would not back this up with any paperwork. The Reno FSDO required it (back into Phase 1 for testing @ 5hrs) for the races, so I did it, but the paperwork ended up in the round file at Reno before all was said & done.
Call me confused!!
At any rate, the aero thing sounds like a similar misfire - get back with the FSDO & get it straightened out. Should be easy?
Carry on!
Mark
11-29-2011, 08:18 AM
Major change...
I interpret a major change of prop to be associated with the type of prop, fixed or constant speed, NOT the make or brand of the prop...
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
11-29-2011, 09:02 AM
Operating Limitations
DARs are required to go over the Operating Limitations in detail with builders getting an airworthiness inspection. Buyers of second hand machines seem to not have the same understanding obviously since they were not there for the original brief. In fact, I've met a number of new buyers who either did not get the Ops Lims with the plane, or did not understand that the Ops Lims are actually a part of the 'pink slip' Airworthiness Certificate and must be carried in the plane.
I would suggest that all non-builder RV owners actually read their Ops Lims and ask their questions now, not after a ramp check.
I recently helped a buyer of a Pitts Model 12 acro machine that had been used in airshows discover that the FSDO inspector who issued the original airworthiness cert had certified it as NON-AEROBATIC. Three owners had flown extensive acro in it.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
