Hey George, I just rented a hangar at CYNJ across from you.
As for your seatback latch, have you considered making a bulkhead (Al, wood, plastic) that would be hinged to the floor in the baggage compartment, and provide a barrier or crumple zone between the baggage and seatback?
Seems to me that without a bulkhead, even if the seatback is latched, the baggage will still impact the seatback and potentially cause injury.
Depending on how you did it, you could use the area between the bulkhead and the seatback for storage of lighter items, and put the heavy items aft. It would be easy to fold down the bulkhead to gain access. A strip of velcro at the top and the back of the F705 would keep it from flopping backwards, but something more secure may give better impact resistance (camlocks?).
Could be made quite light, because it's only required to absorb energy and deform, not carry structural loads.
Vern
Crude Drawing:
