Old 11-20-2011, 11:35 AM
Clarkie Clarkie is offline
Default Dumb question
I am in the process of setting up my shop in the garage with the intention of starting the tail kit in a few weeks. That said, I noticed my garage floor is not level and slopes roughly 2 inches from its high point to the the low point at the garage entrance (intentionally done by builder for water drainage purposes.)
My question is this: Do my building surfaces have to be dead on balls level to build this thing? I was planning on building a few workbenches on casters to have the flexibility to move stuff around as I need to.
Thanks.
Old 11-20-2011, 11:45 AM
AltonD's Avatar
AltonD AltonD is offline
Not a problem.
No need for a level work bench to build the empenage.
You can build a wing stand and level it as needed.
The fuse will have to be leveled occasionally but it is done on saw horses.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 11-20-2011, 11:57 AM
Thanks! Can't wait to start.
Old 11-20-2011, 12:02 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Tom, what are you building?
A prepunched kit like a 10 is not overly critical with this, but an early design like a 3 it is critical to have an accurate jig-----and that can be done on a sloped floor, but it would be subject to needing reriging if you moved it.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-20-2011, 12:58 PM
AltonD's Avatar
Tom, what are you building? ....
According to his profile, he is interested in a -7.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
