Old 11-20-2011, 08:16 AM
aeropunk aeropunk is offline
Default Translucent-Insulated Ring Terminals
I just finished watching one of EAA's Hints for Homebuilders videos on Crimping Wire Terminals, in which the instructor, Kas Osterbuhr, mentions early on that there's a difference between terminals with opaque-colored insulation vs. the "correct" translucent insulation.
We're just getting started doing anything electrical, and still learning, but I'm afraid we used a few of the opaque terminals when installing our capacitance fuel senders.
Questions:
(1) What's the technical difference between the opaque vs. the translucent terminals?
(2) Anyone have a decent online supplier, brand names, or part numbers (Mouser, etc.) for stocking up on some spares? (Kas mentions the AMP brand?)
(3) Should we replace any opaque connectors we may have used on the fuel senders?
Thanks in advance!
"When the ships returned from a mission, everybody watched for them. They came lining back
to the field in flights of four, flying tight show formation with the black smoke fading in parallel
streams behind. They seemed to be most indestructible then. They were of frozen silver."
~ James Salter
Old 11-20-2011, 08:49 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Questions:
Thanks in advance!
1. The translucent (good) ones have a metal sleeve that grips the insulation portion of the wire as well as a smaller sleeve that does the actual electrical contact with the wire.
2. Mouser has thousands of types and needs a lot of sorting out. Go to Stein for the types we need
http://www.steinair.com/terminals.htm
3. Probably, especially if it is easy to access now...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-20-2011, 08:58 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Steinair
(2) Anyone have a decent online supplier, brand names, or part numbers (Mouser, etc.) for stocking up on some spares? (Kas mentions the AMP brand?)...
Check the Steinair ad to the left of the screen, a really good supplier. They've got a kit that will set you up with everything you need.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-20-2011, 09:16 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Steinair
Gil is right on. Buy the ones from Stein, lots of them. Get a full selection. They are cheap and if you mess one up, toss it.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 11-20-2011, 09:23 AM
N427EF N427EF is offline
Default Difference?
The big difference is the seamless ferrule.
On the cheap version you will see the ferrule split.
Go to Stein you can't buy the wrong connectors there.
A kit would be best to get you started.
The cheap ones are not going to automatically fail especially not when they are rigidly supported and free of vibration.
As Gil pointed out, if they are easy to access replace them.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 11-20-2011, 09:33 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Agree, go with Stein, or B and C.
There are two things to consider in purchasing these terminals, one is wire size, and the other is stud or ring size.
I bought a hundred of each of the three common wire size groups, in #6, and #8 stud size.
Also a hundred of each of the wire size groups for the female fast on tabs.
Also, got a hundred of each male, and female D sub pins.
Got a clear plastic compartmented box at Ace hardware, and have all of the terminals organized in it.
For a few extra $$$ you can save a huge amount of time and frustration looking for the correct terminal.
And, by the way-----get good strippers and crimpers too.
Stein has them.
Now about wire..............
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-20-2011, 09:49 AM
az_gila's Avatar
Smile
I think it is a bit more than the seamless ferrule. It the metal insulation grip sleeve too. Look down the end and you can see the sleeve. Compare it to a Pep Boys part...
This is a good illustration -
Gil Alexander
Old 11-20-2011, 10:03 AM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
Another good supplier is Terminal Town. They also have very useful tie clamps and nylon versions of Adel clamps.
As for your connections with perhaps dodgy terminals: if it's convenient, cut them off and use proper terminals; if not convenient, just move on.
You will need the Ideal wire strippers and at least three types of crimpers and terminals for your build. See the Aeroelectric Connection for great advice on all of this. Don't be put off by the amateurish nature of the website, dig around on it and you'll find very good reference material.
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 11-20-2011, 10:36 AM
Brantel's Avatar
Brantel Brantel is offline
The opaque one's insulators are made out of PVC...
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-20-2011, 11:22 AM
az_gila's Avatar
Smile
Not always - here's a nylon non-translucent one - I linked it out of the Mouser catalog.
http://www.te.com/catalog/pn/en/328657
There are so many options (Mouser - 118 matches on insulated, 22-18, ring terminal) it's better to just let one of the VAF vendors sort it out...
Gil Alexander
