Lycoming covers have a larger radius at the top. Doubt it helps much. My rocket has the same problem and I've seen where some builders have bonded with RTV a piece of rubber baffle to keep the rocker cover from bumping.
I've been working on some roller rockers so I've checked the clearances inside the covers...there's just not much room between the pushrod end of the rocker and the cover when the valve is fully open.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
