Old 11-18-2011, 03:39 PM
Berchmans Berchmans is offline
Default Dynon flight dek 180 & Garmin 96C
I am looking for some guidance on the the interface between the flight dek and the garmin 96c. The Power/data cable for the garmin has 4 wires. Red, black, brown and white...The brown and white cables are the data cables and I was trying to find out where these cables should be landed on the Flight Dek 180...anyone?
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2020
Old 11-18-2011, 03:51 PM
Brantel's Avatar
Brantel Brantel is offline
Connect the data out wire to the serial in pin listed on the D180 user manual. You will also need to ensure that both share a common ground.
There is no reason to connect the data in wire to the dynon's serial out pin because it does not send anything to the gps.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-19-2011, 06:17 PM
Default data wire
Ok...which is the data out wire? the Brown or white one?
Burke Wick
Flying RV 8
Anchorage, Alaska
