Old 11-17-2011, 08:43 AM
ALMARTON ALMARTON is offline
Default Bluetooth issue with Zulu headsets.
Hi Folks,
I tried a friend's panel-powered Zulu headset and was able to connect both headsets at the same time to one celular phone to listen to a music.
So I bought myself a Zulu headset , but the battery powered one and was not able to connect both headsets to listen the same music from the same cell, with mine headsets I can only connect one at a time to music or the other one to place calls.
Anyone knows if am I doing something wrong or it is really a limitation of the battery-powered version? I asked Lightspeed Company about that and still had no replies....
Thanks in advance
Alexandre "neck" Marton
Brazil
RV7A (8/2015 built by FLYER)
Lycoming 180 HP - YIO-360-M1B, Hartzell C2YR-1BFP/F7497? 72??, Garmin panel - G3X Touch, GTN650, GTS800, WX-500, BATT CONCORDE RG-25XC AEROBATIC SEALED.
Others: RV9A
Lycoming XIO320-D1A, Hartzell HC-C2YL-1BF/F7663-4 , CS GOVERNOR MTV-12-B, DYNON D180
AND GARMIN AVIONICS
(Sold with aprox 300hrs flown from Dec/2010 -- JUN/2014)
Old 11-17-2011, 08:50 AM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
Maybe it is a phone issue? Is your phone the same as your friends? Can your phone connect to two Bluetooth devices at the same time?
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
Old 11-17-2011, 08:54 AM
Yes it is the same phone. Have you tried and suceeded connecting two battery-powered version of Zulu to a same cell to listen to a same music?
Brazil
Others: RV9A
AND GARMIN AVIONICS
Old 11-17-2011, 10:32 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I've never gotten my two 1st generation Zulus to "pair" simultaneously to the same phone at the same time either. It's my understanding that bluetooth headphones need to support something called "Multipoint mode" in order to have two or more of them connected simultaneously to the same bluetooth host and the original 1st generation, battery-pod Zulus probably don't support this advanced bluetooth mode.... only simple legacy pairing mode.
Neal Howard
Airplaneless once again...
Old 11-17-2011, 11:23 AM
That is also my understanding as is that the panel-powered does support multipoint connect 'cause I did it once!
So I bought the wrong ones...
Brazil
Others: RV9A
AND GARMIN AVIONICS
