Old 11-14-2011, 12:38 PM
SamZ SamZ is offline
Default Strip lights flickering when transmitting
My strip panel lights on my RV-7 all of a sudden started flickering every time I push the PTT button. Anyone have any idea what might cause this. Thanks for your help.
sz
Old 11-14-2011, 03:00 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Do you have a dimmer? If so, it's probably picking up some RF when you transmit. Which dimmer do you have? If you have LEDs, the LED dimmers are more susceptible to picking up RF it appears.
I had a similar problem with my LED strip lighting and went with this dimmer and it solved the problem:
http://www.ebay.com/itm/PWM-dimmer-s...item20bee26f20
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 11-14-2011, 03:09 PM
Thanks for the info...not sure what type of dimmer it is. I'll have to check. Either way, i'll pick up one of the dimmers you suggested and see if that fixes it. Seems to be the simplest solution. Thanks again.
sz
Old 11-14-2011, 03:16 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default A bit of thread drift...
I have LED post lights in my RV-4. The post light base acts as the negative terminal, using the airframe as the ground.
All of the LED dimmers that I find require that both LED positive and negative wires go to the dimmer. I can't see how to do that with post lights.
Can someone point me to a dimmer that needs only the positive lead from the LED?
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 11-14-2011, 03:23 PM
Here is the exact dimmer that I have. Sold by Britta Products. I'm not sure if it's the same one that you posted, I can't get to ebay from my work computer.
oops, forgot to post the link to my dimmer.
http://www.amazon.com/Lighting-Contr...=pd_sim_auto_2
Old 11-14-2011, 03:32 PM
Pat Hatch's Avatar
Sam,
Here is the direct web site for the manufacturer:
http://www.kicklighting.com/PWM-dimm...ch-for-LED.htm
The dimmer you have appears to be the same Pulse Code Modulation (PCM) circuitry as mine, just a different manufacturer. In any event mine is cheaper by half. I don't know, you may just have a bad one or going bad, so as long as you have to replace it, I would try this one.
Pat Hatch
RV-7 (Sold)
Track Me
Old 11-14-2011, 03:37 PM
Pat,
Thank you....i'll give this one a try and hopefully it works.
sz
Old 11-14-2011, 04:40 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!!!!
Sam, welcome aboard the good ship VAF.
So, tell us about your plane, and some photos???
Good to have you here.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
