  #41
Old 11-15-2011, 08:21 PM
AlanTN AlanTN is offline
Default Lower nose --- glide farther!
"When flying slower than L/Dmax, raising the nose will eventually lower the aircraft."
Dave's last statement needs to be burned into the brain of every pilot. In an approach at below the best glide speed, to glide farther you have to lower the nose. Totally non-intuitive!
Old 11-16-2011, 05:09 AM
Peterk Peterk is offline
Originally Posted by AlanTN View Post
Thanks, Larry. Do you have any idea what your RPM was? It is interesting that Peter used 3.8 gph and you only used 3.2 gph. It must be those rivets that you filled in! :-)
Actually Alan...since Larry lives in corn country, he is allowed to use fuel without ethanol (go figure) while those of us that live in civilization are forced to burn corn "squeezins". There ya go!
Pete
Old 11-16-2011, 06:24 AM
Originally Posted by Geico266 View Post
I went flying tonight and set the throttle to 97 mph. Knots are for ships.
Fuel burn was 3.2 gph.
Hip-hip-hooray, finally someone did it and the question is answered.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 11-16-2011, 07:36 AM
Mich48041 Mich48041 is offline
Some builders have been known to drink corn "squeezins"
Joe Gores
Old 11-16-2011, 07:47 AM
gblwy's Avatar
gblwy gblwy is offline
Default 600
So 19.8 galls divided by 3.2 multiplied by 97 mph gives 600 statute miles as the absolute range.
Old 11-16-2011, 12:21 PM
Here in Tennessee we can also got non-ethanol gasoline. One source I have says that E10 has 97% of the energy that gasoline has. So that would only account for about 0.1 gallon per hour difference.
Actually if Larry burns 3.2 gallons per hour at 97 mph indicated, that would be about 112 mph TAS at 7500. So 3.2 gallons will get you about 693 miles.
What is your secret, Larry?
Old 11-16-2011, 12:46 PM
Geico266's Avatar
Geico266 Geico266 is offline
Joe Gores
And the problem is ????
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 11-16-2011, 12:48 PM
Geico266's Avatar
Wait a minute. If you climb while flying (according to your calculations) you could get an extra 20-40 miles of glide at 13 to 1! My weak attempt at humor is meant to say you better calculate a fuel reserve.
Old 11-16-2011, 12:49 PM
Geico266's Avatar
Tail winds.
Old 11-16-2011, 12:54 PM
Geico266's Avatar
RPM was 4260. I took a picture of it.
I would lean toward the 3.8 actually. I just sent my Dynon in and they may have recalibrate my K factor. I think it is fairly close, but I am not 100% sure until I do some verifying.
I would like to think it was superior flying skills.
