11-08-2011, 04:48 AM
AFS harness to fuel pressure sensor
A question to AFS users.
The wiring diagram only shows a single pin out to the fuel pressure sender but their are 2 tabs on the pressure sender unit. I dont want to assume one is for ground but thats probably it.
Anyone else know?
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
11-08-2011, 05:39 AM
Hi Paul,
Looking at AFS's web store, I don't see a dual connection fuel pressure sender (bottom of page 1 and on page 2):
http://97.74.21.14/webstore/category-173/#1
Which AFS model is this for?
Looks as if AFS typically uses either Stewart Warner (gold colored) or VDO senders (silver colored). If you can you get a manufacturer part number, it can be looked up.
/\/elson
RV-7A Tip-Up
NW Austin, TX
11-08-2011, 05:56 AM
Anyone else know?
I don't have an answer, but I would recommend posting to AFS' support forum directly. Rob and/or Trever usually respond within hours.
bob
11-08-2011, 10:09 AM
If you have a two terminal sensor you need to ground one of the terminals.
Rob Hickman
Advanced Flight Systems Inc.
11-08-2011, 10:38 AM
bob
Or you can just wait for Rob to respond here....
11-08-2011, 10:41 AM
Thanks Rob
Thanks Rob, cant wait to take your product into the air.
Guy, hope all is well in ABQ.
Avidyne IFD440
