Old 11-06-2011, 02:52 PM
tonyjohnson tonyjohnson is offline
Default toggle switch sizes
I am looking for a toggle switch (SPST) to operate my back up battery. I ran out of pre drilled spaces on my panel for 15/32 size toggle switches, but I have a couple of .45 holes for circuit breakers.
If I could find a toggle switch that will fit into that hole it will make the project a bit easier. I googled and did a search here but could not find such a switch.
Does anyone know of such a switch? In the alternative, where did you put your switch for your backup battery, if not on the panel. Finding a good alternate location would accomplish the same purpose for me.
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
Old 11-06-2011, 03:14 PM
Mel's Avatar
Mel Mel is offline
Default Am I missreading something?
Since 15/32 (0.46875) is larger than .45, why not just drill the holes out to 15/32?
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-06-2011, 03:28 PM
Default drill it out
Mel,
I can do that although the keeper hole would no longer be located in the correct place and I don't want to risk buggering up the nice new carbon fiber fronting on my panel.
Tony Johnson
RV8A "Badboy" N12TJ
Old 11-06-2011, 03:38 PM
Mel's Avatar
Mel Mel is offline
You would only be removing .0094 of material.
.46875 minus .45 equals .01875 (dia) divided by 2 (radius) equals .009375 mat'l to be removed. Surely your "keeper" notch is at least .063.
Old 11-06-2011, 03:54 PM
Default thats probably what I will do
Mel,
Thats probably the route that I will take. I was over thinking the issue. Thanks for helping me think it through.
Tony Johnson
RV8A "Badboy" N12TJ
