Old 11-05-2011, 12:12 AM
Stewie Stewie is offline
Default Countersink following dimpling?
Hi all-
Was impressed by the extremely smooth countersunk HS skin I saw on a neighbor's -4 last week. It was so smooth, it looked like it had been back riveted. I know it is not recommended to CS aluminum that thin, but I was wondering: could a person dimple the skins, then run a CS in the dimple? You'd get the shear stress benefit of dimpling, and the aesthetics of a CS hole without taking away much material. My emp is finished, and I was told the slight undulations along the rivet line are typical, but I thought I might try this on the wing.
Searched the forums for this but couldn't find anything, please redirect me if this has been previously discussed.
Thanks, everyone have a good weekend.
Eric
Old 11-05-2011, 01:36 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default A light pass with a deburring tool works well.
George Orndorf (who made many construction education videos in years past) recommended a light pass with a hand deburring tool after dimpling. Just a few light turns will do the trick. If you produce significant shavings, then you are doing too much. This method has worked well for me, producing nice flush rivetted assemblies. YMMV
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 11-05-2011, 07:44 AM
Av8torTom's Avatar
Default How did you dimple?
Hey Eric, do you use a DRD2 dimpler or the C-frame wack-a-mole method? IMHO the C-frame makes a crisper dimple resulting in a smoother final finish.
N677AT reserved
Superior XP O-320, 160HP
Old 11-05-2011, 09:29 AM
aerhed aerhed is offline
I do that all the time when I want just a little more squareness. As stated, don't even cut through the alclad.
Actual repeat offender.
Old 11-05-2011, 10:04 AM
Tom-
I've got a DRDT2. I suspect that some of the rivet line ripple is coming from the dimpling itself, in addition to the impact of the rivet gun...
Old 11-05-2011, 11:10 AM
jimgreen jimgreen is offline
I back riveted the last 2 skins on the rear fuse of my 7 . For me, c frame dimpling and back riveting has produced the best finish.
But don't forget you are not building a Glasair. Rivets don't have to look super smooth.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
Old 11-05-2011, 01:50 PM
At least once a day I have to (to quote someone else on VAF) tell myself: it's not a Swiss watch, it's an airplane...
Old 11-05-2011, 03:22 PM
9GT's Avatar
9GT 9GT is offline
Dimpling the hole twice with the DRDT2 give really nice results.
David C.
Howell, MI
Old 11-14-2011, 10:18 AM
clevtool's Avatar
clevtool clevtool is offline
Good dimple dies make all the difference in the world! If you take only .002" out of the dimple on .020" skin that is 10%. With good dies you won't have to take any out. If you are not using our dies, buy some, try them, if you don't think they are better than what you are currently using we will give you your money back including the shipping.
http://www.cleavelandtoolstore.com/products.asp?dept=48
Mike Lauritsen
Cleaveland Aircraft Tool
800-368-1822
www.CleavelandTool.com
mike.toolman (at) gmail.com
Like on Facebook - Follow on Twitter - See on YouTube
Old 11-14-2011, 10:46 AM
Mike, I've used dies from the worst (ATS) to the best (maybe yours). I'll match my rivet lines against anyone's. Loser buys dinner. Any takers?
