Old 11-04-2011, 11:20 AM
TThurston TThurston is offline
Default Questions about air tools
I'm currently using a very small borrowed Craftsman air compressor (1.5 hp, 3.3 scfm @ 90psi). It's seems adequate for riveting, but when I use it to drill, the pressure drops rapidly, the compressor starts making refill noise, and the drill slows down. After a bit of slowing, the drill doesn't get any slower, but it's painfully slow. I assume this is the point at which I'm just using up the air being pumped into the tank. I'm looking to upgrade to a larger compressor, but I have some questions.
I'm currently on a 15amp circuit, and don't feel like upgrading at this time. Thus, I'm looking at compressors with this limitation. It seems like the best they'll give me is around 5 scfm @90psi, with varying sizes and pressures of tanks. I'm trying to determine exactly what this means.
1. If I have a a tool that states that it uses 4 scfm, and my compressor delivers 5 scfm, then I can use that one tool forever, right? The pump will run 80% (or so) of the time trying to keep the tank full, and it may get hot (and damage the motor). Is this what the scfm numbers mean? In the case above, would the tank size make any difference?
2. One compressor has a 30 gallon tank, and the other 15 gallons. If both compressors have the same scfm rating, I assume that the bigger tank takes twice as long to fill. It will also go twice as long suppying air before the pump starts to refill it (assume the same max pressure and refill point). But then, if a tool is stilll using air at a constant rate, what difference will there be in how the pump runs to trying to refill the tank?
3. I'm guessing that the total amount of time the pump runs is only related to the rate at which air is being consumed by my tools (plus the time to originally fill the tank). Thus, if I start every day with an empty tank, my pump will run for a longer total time if I have a bigger tank. Right?
4. This runs counter to the conventional wisdom that a bigger tank is better. I'm guessing that the main advantage of the bigger tank is that it allows you to consume air at a greater scfm than your pump can supply for a longer time before the pressure drops unacceptibly low. But if your air consumption is below your pump's scfm or above it and sufficiently intermittent, then there is no advantage to a big tank. Right?
5. Related to the tank size questions is one of tank pressure. If tank one is pressurized to 120 psi, and the other to 200 psi, I assume the second tank is has a capacity to supply air that is (200/120) greater than the first one. In other words, it's like having a tank that's 5/3 bigger.
6. When I adjust the pressure on my rivet gun, I understand this means I'm not only changing the rate at which it hammers, but also changing the rate at which it consumes air. I assume this also applies to other tools. For example, if I get an air die grinder, and mount a 1" scotchbite wheel to use for deburring (or whatever), I may find that at 90psi the grinder turns "way fast", but uses air to quickly for my compressor. Could I just put a flow regulator on the die grinder, drop the pressure to something that would give me "adequately fast", and use enough less air that my compressor can keep up?
7. On a similar note, if I see two different versions of the same air drill, one rated at 2600 rpm and the other 4000 rpm, I assue that the faster drill will use air faster (and probably drill holes faster, too). Is this right? (Van's "Tools and Workspace" section of the manual states that a minimum of 1100 to 1200 rpm is required of a drill.)
I know this seems like a foolish lot of questions. It's kind of like of like the flying rule: Obtain all available information before flight. So I try to obtain all available information before purchase.
Old 11-04-2011, 11:48 AM
aerhed aerhed is offline
Die grinders "eat" air. Suggest an electric dremel tool instead. A good battery drill can substitute for an air drill and once you are off the workbench and into the "boat hull" stage it can be handier than an air drill. No hose, just grab and drill. I still like the 9.6V stick battery Makitas. The slim handle is easier on the wrist and gets into tighter spaces than the big battery ones. The new NiMH batteries will drill lots of holes. Plus, the controllable speed does a better job on countersinks & deburring. I didn't even use an air drill on my last 2 airplanes. Biggest benefit for me is not having to listen to that stupid compressor or wait for air pressure. In fact, I think an air drill is a dinosaur mostly.
Actual repeat offender.
Old 11-04-2011, 11:52 AM
rleffler's Avatar
rleffler rleffler is offline
I'm assuming a 15a, 120v circuit. That's going to be the biggest limitation of what options are going to be available to you.
You'll want the largest tank you can find, probably 30 gallons. This is for drills, sanders, etc. Yes the motor will run longer, but also the extra capacity will also keep the tool running longer at the appropriate speed.
You'll see a lot of similiarities since the Lowe's and Home Depot oem brands are really Campbell-Hausfield (sp?) compressors. They'll have different color paint and a different part number, but the performance numbers will be similiar.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-04-2011, 11:53 AM
DaAV8R DaAV8R is offline
Default Air tools
Trying to keep this simple:
A small air compressor isn't going to keep up with continuous operation type air tools. It will help to turn down the pressure to the tool.
I think most of your comments on storage and recovery are reasonably accurate. Bear in mind that a compressor advertised with a 200 psi tank won't necessarily recover any quicker that a compressor advertised with a 125 psi tank. Storage volume and recovery rate are two different things. Air storage can be compared using either tank volume or pressure (or both).
The manufacturers are trying every way they can to market their rinky dink compressors as "large".
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 11-04-2011, 12:53 PM
Greg Arehart's Avatar
I would be surprised if you could run an reasonable-sized tank out of air using a drill. You would have to have the drill running constantly for quite a while to do so. With a die grinder, more likely to run out of air, but most of the reasonable-sized compressors will do you fine most of the time.
If I had it to do over again (which I just might one of these days), I agree with Aerhead, one can relatively easily build an airplane with electric tools and not use the compressor except for driving rivets (and painting if you do that yourself).
greg
Greg Arehart
N 7965A
Old 11-04-2011, 01:25 PM
jwilbur jwilbur is offline
Default Fast electric drill
Just a few weeks ago I bought this corded Craftsman Evolv drill for $30.00. It runs up to 2500 RPM, has a keyless chuck, and never runs out of air. So far, it's just about the best tool purchase I've made for the money - right behind my $120.00 Tungsten bucking bar.
http://www.sears.com/shc/s/p_10153_1...7&blockType=G7
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 11-04-2011, 03:19 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I had a similar restriction, I bought a Harbor Freight compressor, $99 with about a 30 gal tank I guess, upright model. It has ran my air drill, die grinder, and a half dozen other air power tools quite well, no complaints, for my whole construction phase. And it runs on a 15 amp circuit.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 11-04-2011, 03:26 PM
bret's Avatar
bret bret is offline
I just bought the new dewalt 12v with the new batterys, 2.4 Lbs and runs forever.
Old 11-04-2011, 04:09 PM
Sig600 Sig600 is offline
I have a 26 gal compressor and even with the air turned down the drill still keeps the motor chugging. Had an old 18v cordless with a spare battery that is much better. Keep one battery charging all the time, never ran out of juice during a build session. The air drill is def better than an electric though if you have a large enough tank. A dremel is also a good tool to have, as has been mentioned. And a drill press. And, and, and.... (you get the idea!)
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 11-05-2011, 08:06 AM
Av8torTom's Avatar
Default Oil lubricated vs. Oil-less
To me the difference comes down to oil-less or not. The oil-less compressors have some advantages, but are significantly louder and are not really meant to be running continuously. I picked-up a 25 gallon oil lubricated compressor on craig's list for $80. I'm very happy with it - especially with the noise level.
N677AT reserved
Superior XP O-320, 160HP
