Old 11-03-2011, 06:55 PM
thinkn9a thinkn9a is offline
Default Flap motor question,.... what now??
Flap motor stopped on the way home from long trip. Luckily it managed to pull them up before giving it up finally. (failed to cycle down on initial landing attempt.... down and back up after go around second attempt,.. never did trip a breaker)
So,.. no joy, on landing at home...after checking again in hangar, after arrival home,.. .then again tonight before maintenance pull down,.. so, went ahead and pulled out unit.
It is the "new" Vans unit... made in 03/03. (Vans engraved on "block)
On a whim... decided to check the motor on the workbench prior to teardown,... especially as it was not the "old style" grease problem motor.
Well.... 9 volt battery drove it both ways... even with end restrained from turning. Hmmm,.. did I really have voltage at the unit? Checked and Yep,.. full voltage at unit in plane.
So,.. what is the recommendation?
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 11-03-2011, 07:09 PM
Vlad Vlad is online now
Flap switch glitch maybe? Or ground wire loosing contact during vibration in flight?
Old 11-03-2011, 07:53 PM
bird's Avatar
bird bird is offline
Default Voltage
This is an interesting problem, I would think, most likely you have a loose or bad connection. Remember, just because you have full voltage at the motor, that doesn't mean that the circuit is capable of providing the power (amperage) necessary to operate motor properly. Double check all connections, swithes, grounds etc. Hope this helps. Please post what you find. Thanks.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 11-03-2011, 08:05 PM
turbo's Avatar
turbo turbo is offline
next time it does it check voltage. could be at the breaker. fly with a tester.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 11-07-2011, 06:15 PM
Default loose connection??? nah,.. it's been good for 300 hrs.....
oh well,... guess these planes do tend to vibrate a bit,.....
Bird had it right.
Loose connection,... even if I tried to convince myself that the little wiggle was due to my strong yank on the wires. After I tightened up the connection to the switch, all checked out and then worked after reassembly. Sure wish I would remember to check the easy stuff first.
At least I usually remember to check here with the brain trust before burning a lot of hours.
9A -QB
N211LV
