Old 05-19-2006, 02:20 PM
Dean Dean is offline
Default Stewart Warner Fuel float wiring
I have the Stewart Warner fuel float sender units for my RV-7. I cannot locate a wiring diagram. Do I hook one wire to the center terminal and the other from one of the 5 mounting screws to ground? Thanks, Dean
Old 05-19-2006, 02:31 PM
sf3543 sf3543 is offline
Yes...the center terminal should go to the gauge. No need to ground the unit since screwing it to the tank will ground it.
Old 05-19-2006, 05:31 PM
Thanks for the response. Dean
