Old 11-03-2011, 09:37 AM
Cadstat's Avatar
Cadstat Cadstat is offline
Default conditional inspection
How much should I expect to pay for a conditional inspection if I assist by pulling all the access panels, covers, carpet, cowl, fairings, ect?
I don't think a compression check is required. Is that true?
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
Old 11-03-2011, 09:47 AM
aerhed aerhed is offline
Default FAR 43 App. D (d3)
(3) Internal engine?for cylinder compression and for metal particles or foreign matter on screens and sump drain plugs. If there is weak cylinder compression, for improper internal condition and improper internal tolerances.
If you're having trouble getting it done, maybe I could do it. Bring it to me ($300 plus fixes) or I could fly down (more money).
Actual repeat offender.
Old 11-03-2011, 04:25 PM
turbo's Avatar
turbo turbo is offline
to answer your question, i would somewhere between 100 to 300 $$$$$$.
0$ is best. might be a close A&P friend.
barter is also doable.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
