Old 11-03-2011, 07:30 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Looking for an O2 Regulator
I'm working on a "special" O2 system, and need to find an Oxygen-safe first stage regulator that will screw onto a standard CGA-540 valve (typical Aerox portable bottle) and put out from 50 - 100 psi through a standard pipe-thread-type fitting (to which I can connect a medium pressure hose).
Searching the 'net is tedious with these requirements - we've got so many folks here on VAF, I figure that someone might pop up and say "hey, I make those!"
{Once I have the 50-100 psi O2, I'll pipe it to a second-stage diluter/demand regulator that I already have. I have used a borrowed bottle/reg for the front end of this before, but that isn't always available to me, so I want to roll my own that will work with bottles I have for our canula systems.}
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-03-2011, 07:56 AM
gnuse's Avatar
gnuse gnuse is offline
This is not a scuba first stage regulator you are seeking? I can help if it is. I did this to use for emergency strut inflation with scuba tank for my 310. 310 is gone.
George
"God does not deduct from one's time on earth that which is spent in the air."
