Old 11-02-2011, 07:07 PM
JimWoo50 JimWoo50 is offline
Default need key for my tailwheel
Does anyone know the part number for the spring loaded key that fits in the tailwheel shaft to keep it from swiveling? Its for an RV-6 with stock tailwheel assembly from vans. tia.
Old 11-02-2011, 07:14 PM
GaryChatelain GaryChatelain is offline
Tia,
Go here. This guy is great. He has been very helpful to me.
Gary
http://www.flyboyaccessories.com/
Old 11-02-2011, 07:19 PM
Sparky's Avatar
Sparky Sparky is offline
If the problem is that the key sticks, from what I've read you can file off the burrs that form with use and relubricate to restore normal function.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 11-02-2011, 07:33 PM
Default The problem is I have no key
was never installed.
Old 11-03-2011, 08:31 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Here's the exact link: http://www.flyboyaccessories.com/sto...h8dgjam72vhud2
You might also need to dress the cutout notch in the steering control arm with a file. If you ask him, Vince will email you a couple PDF files with pics showing how to make the pin and notch fit a little better.
Neal Howard
Airplaneless once again...
Old 11-03-2011, 08:43 AM
Ironflight's Avatar
VAF Moderator / Line Boy
If you want to buy it from Van's, just give them a call - they know the part number. There are many of them hiding in dark corners of hangars and workshops - after being launched by their springs!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-03-2011, 09:26 AM
Default I think Ill order 2
just in case mine gets launched!
Old 11-03-2011, 09:56 AM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Default Key Slide
Van's P/N for the Key Slide and Spring:
WD-102C FSTW KEY SLIDE $6.35
SPRING LC-023AB-11M FSTW SPRING $.090
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 11-03-2011, 10:20 AM
Default Thanks Joe. eom
my order is in.
