Need Hartzell F2 SERIES PROP GOVENOR Assembly Instructions
I removed the control input shaft on my Hartzell F2 prop governor to replace a leaking o-ring and I have obviously assembled it incorrectly as the high RPM stop has moved and I get low oil pressure (14 PSI) at idle now. Do any of you have information/instruction on assembly of the input shaft? I can do it by guessing at the proper position of the shaft gear, but it would really help if I did it right the first time. Thanks for the help.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
