Old 11-01-2011, 06:15 PM
tturner tturner is offline
Default Slider canopy - Stop outside handle from striking bow
I had just finished the canopy on my RV-6 when someone shut the canopy with the handle turned the wrong way and it took a chip out of the bow over the windshield. I looked on the forums for a fix and the only one I found had you file down the outside handle but mine looked like it would still hit even with that. Below is a link to fix I designed to prevent this from happening.
http://ptcaviation.com/wordpress/?page_id=116
Tommy Turner
Fayetteville GA
RV-4 sold
RV-6 sold
RV-8 Flying
RV-14A building
Old 11-01-2011, 07:03 PM
Frank Smidler Frank Smidler is offline
Default Filing down outside handle works
I had the same problem on my RV6 and still have the chips in the paint to prove it. I filed a taper on the bottom side of the outside handle and it now clears without it hitting.
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
Old 11-01-2011, 07:06 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Tapered bottoms have been the standard. Of course, I might never have known, if I hadn't seen it on the interent a few years back.
L.Adamson -- RV6A
Old 11-01-2011, 07:11 PM
frazitl's Avatar
frazitl frazitl is offline
Default One way or another,
this problem needs to be dealt with on all sliders. Van's should at least make a note on the plans. I was able to trim the underside of my outside handle, but were that not possible, your solution looks like the answer. Hope you hadn't painted yet....
Thanks for your posting.
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
Old 11-01-2011, 07:35 PM
Default Lost Gold
I'm sorry you didn't see the fix that was presented in this forum. There are quite a few refinements that come up here and if you are not following the daily post they are just so much lost gold. I saw the solution proposed here to taper the lower surface up to the point that it clears the windscreen flange when it is in the reverse orientation. I also hit mine once before I quickly incorporated the fix. Your's looks good also and I'm sure it will be picked up and used by others.
Bob Axsom
